NI TestStand
problem using python in teststand
when i select the Py module, the following error appear "impossible to find the specifyed file".
the file is present, i'm able to open using the proper button on the right of the page.
i checked:
  • CPython interpreter installed and added to your PATH variable
  • 'pywin32' installed
  • python version configured on adapter configuration dialog
  • 'numpy' installed
thanks claudio
(764 Views)
Hi Claudio,
doesn't TestSTand ask you to specify a path? Where is tthe py file located in respect to the .seq file?
Oli
(752 Views)
the file is in the same folder of .seq file
(747 Views)
Are your search path settings standard or are there modifications?
(739 Views)
not modified,
the first path is "Current sequence file directory"
thanks for the support
Claudio
(724 Views)
Ok, so the Python adapter can be a bit special sometimes from what I've seen.
The NI helps suggests "resetting" the adapter by File-> Unload all modules.
Please check if this helps!
If it doesn't, close the Seqeunce Editor and try again. If this also doesn't help, please try the ultimate IT solution: rebooting the computer... just to make sure 😉
(710 Views)
