NI TestStand
passing data from TestStand to Jupyter NoteBook
decided to start a new thread on how to get Data from TestStand to Jupyter Note Book.
I have tried to follow the steps from http://www.ni.com/tutorial/8847/en/   but it does not work. when I use the call executable, all I get is a window with my Jupyter code. I don't get any results from theTestStand output window either. Below I have modified the Python code to work in Jupyter.
step #4 of the tutorial
#Get input as a list
numbers = input('Enter numbers: ')
total = sum(int(c) for c in numbers)
print("total_Sum:", total)
Step #3 of the tutorial just reading the data from arguments expression
import sys
#Iterate through each element and get data
for n in sys.argv:
print ("total_Sum:", n)
step# 4Error
I don't think I am pointing tho the Argv data?
total_Sum: C:\Users\rata\Anaconda3\lib\site-packages\ipykernel_launcher.py
total_Sum: -f
total_Sum: C:\Users\rata\AppData\Roaming\jupyter\runtime\kernel-357edb9f-22fb-46ff-91e4-272bc740f56d.json
Is it even possible to access Data through Jupyter?
Any help will be greatly appreciated.
WinnieWanda
(2,862 Views)
I don't think your post worked quite like you expected.  What is your question?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,801 Views)
I suppose not. I have just figured out what I wanted to achieve. Thank you for posting something Smiley Happy
(2,796 Views)
