NI TestStand
parameters for dynamic sequence
I would like to know how to pass parameters to a sequence that is call dynamicaly.
(3,365 Views)
Hi
just see this thread
http://forums.ni.com/t5/NI-TestStand/how-to-crate-an-action-step-in-teststan-using-C-along-with/td-p...
there is a small example which creates a sqeuence call dynamically by using TS expression and api
Hope this helps
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,350 Views)
On the sequence call module panel. in the lower right hand corner there is a button to load prototypes. Click it to load the prototype of one of the sequences you wish to call. The parameters will then show up and you can fill in what to pass for them.
Hope this helps,
-Doug
(3,340 Views)
