NI TestStand
one numeric output with 2 possible results
Hi all,
I have a numeric output from a LabView Vi that if it passes the test will output a value of either 11 or 15 (both are acceptable) to TestStand.
Is there a way in TestStand to compare the numeric to either 11 or 15 (numeric limit test).
I do not want to set a high limit of 15 and a low limit of 11 as 13 would be a fail.
Regards
Chris
(1,398 Views)
In this case, I'd suggest using a Pass/Fail test with the Data Source set to:
(Locals.Value == 11 || Locals.Value == 14)
And use ReportText to note what the value actually was if needed.
Hope that helps.
(1,376 Views)
You can use PreExpressions Box on the step settings
Define
Add Pre Expression to your Numeric Test Step
(Locals.LVResult == Locals.Limit_01) ? (Step.Limits.Low = Locals.Limit_01) : (Step.Limits.Low = Locals.Limit_02 )
You should get something like
CLA, CTA
(1,372 Views)
Thanks 🙂
(1,320 Views)
