NI TestStand
nilm16
My Teststand 4.1.1 installation did not work as previous and i had some problems with deployments. So i decided to deinstall teststand 4.1.1 and labview 8.5. After re installation nothing was changed.
I removed all NI software using the NI_msiBlast.exe removal tool. To be sure nothing was left i cleaned the registry (first saved the entries and then deleted them). This way i wanted to do a clean re installation.
Installing Labview 8.5 worked fine. Insatlling Teststand was no problem. After the installation the licence information was not asked (Did not haven to enter the serial key).
Now, wen starting Teststand, I get 'The requested license is not available on this computer. (NILM16)'.
Teststand does not appear in the NI License manager!
I ran Teststand verion selector which did not help.
When re installing from the CD, everything goes fine but the problem is not solved.
The system is running on Win XP SP3
How can i start a 'clean install' ?
(3,332 Views)
Accepted by topic author Dirkvh
I used the NI_msiBlast.exe to repair the Teststand files and this worked fine.
Registration worked.
Case closed for me.
(3,319 Views)
