NI TestStand
.net invocation call using testand API in C#
Hi, Am creating sequence in teststand using C# API. So am able to create step but am not able to load the root class, assembly name. I am using tetststand 2019. How do i write the code for root class. also how do i call method in .net invocation
(302 Views)
Since this is the latest thread, you have re-opened , I am going to answer here....
I dug a litlle bit to give you some directions:
- go to Configure -> StationOptions ->Preferences: check Show Hidden Properties
- manually create a .net Step as you would like to create ist automatically.
- one the step properties page, go to Property Browser
the SDATA structure will show you the porperties you have to set
Make sure to create the array elements before trying to access them
(264 Views)
Hi, Thank you so much for taking time to reply. I really appreciate it. I was able to implement solution to my queries.
(254 Views)
