NI TestStand
multiple reports parallel
I now use teststand 2013(engine 5.1).
I have a main sequence which calls sub sequences.
Each sub sequence is a test and must run parallel, each sequence also must generate a report with a different serial number.
How can I achieve this. is this even possible?
gr,
Bart
(4,862 Views)
Hi Bart,
Via this link, you find a white paper. Step 4 descibes what you want to achieve.
Please let me know if this helps.
Bas
(4,827 Views)
Are all of the subsequence calls to the same sequence? If so, you should be using the parallel or batch model instead of having the top level sequence.
(4,822 Views)
