NI TestStand
multiple expressions in value field
I'm using a multiple numeric limit step.
i would like to add a value to the step.numericArray[0] and the same value to a local.xxxx
(see picture)
is that possible or do i have to do it for the local.xxxx in the post-expression ?
br
Nikolaj
(4,557 Views)
You can't do that in a parameter.  You will need to do it in a post expression.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,504 Views)
Hi
Why not using only Locals.Camera.K1 in Parameter field and using
Specify Data Soure for Each Measurement with Locals.Camera.K1 ?
or this will work, too.
regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,488 Views)
