NI TestStand
message popup size
I was wondering if it possible so modify the size of the response string box.
The default size does not show me the complete serial number that the operator will scan but only the last 3 digits.
I want to set the size of the response bigger so I can see in one shot the complete serial number scanned.
(2,921 Views)
I'm not aware of a step setting to change the size of the popup. The hacky way of doing this is to pad the front and rear of the text with spaces. This will increase the length of the popup. Yon can also make the font larger as well to achieve the same effect.
CTA, CLA, MTFBWY
(2,920 Views)
