09-07-2012 01:24 AM
How to disable the path comming on the test report.
please see the attachment for clear understanding
11-30-2012 04:11 PM
For the HTML report you will need to customize reportgen_html.seq
In this sequence the callback "AddSequenceResultToReport" has a step "Add Sequence File Path".
Although I have not tried but see if this helps to remove the path from report.
12-01-2012 09:49 PM
What version of TestStand are you using?
In TestStand 2012, the location is actually in the AddSequenceResultToReport_Impl sequence. You would need to comment out the following lines:
I have also had requests to do this to save space on the report, but I accomplished this on a text report.
Good luck,
PH
