NI TestStand
java teststand - Error 1500 Cannot find class
(2,364 Views)
as pointed out in TestStand Help, the meaning of the error code you encountered is:
The specified class name was not found in the class path. Verify the class name and that the file that contains the class exists in the class path.
I have found some threads in this forum that are related to the same topic.
Hope this helps!
Alessia
(2,335 Views)
