NI TestStand
how to write C++ with LabVIEW
hallo
I am trying to write this C++ prog.
for( step2=0, step2<3, step2++)
  Y=step2;
  for(step1=0, step1<11, step++)
    X=step2;
    A=measure the Sensor;
    save X,Y,A in a table;
with labVIEW (see attachment), the PROBLEM is  Y the first step Y=0 (O.K) the second step Y still =0 instead of 1 and the third Y=1 instead of 2 . where is the problem ?
 Thank you in advance
Toni
(3,221 Views)
You will get a better response if you re-post to the LabVIEW forum
http://forums.ni.com/ni/board?board.id=170
as this is the TestStand forum.
Also, state which version of labVIEW you are using.
Regards
Ray Farmer
Message Edited by Ray Farmer on 03-18-2008 08:43 AM
Regards
Ray Farmer
(3,220 Views)
Hi Ray
Thanks for your reply. I re-post it on the other Forum, do you mean they can help me ?
by the way I am using LV 8.5
Thank you  again
(3,213 Views)
Hopefully, but there is no guarantee.
If I had access to LabVIEW at this time I would of looked at your VI and provide an answer for you. But pointing you at the correct forum should get you a quicker response.
If you haven't had a reply by the end of the day, I will have access to labview and therefore can look at your VI.
Regards
Ray Farmer
Regards
Ray Farmer
(3,207 Views)
