NI TestStand
how to transfer a pass/fail result to a variables
How to transfer a pass/fail result to a variables ?
when a step has performed , I'd like to return a value to a variable .
thank you in advance..
(2,917 Views)
If the step is still active, then use the lookup "Locals.MyResult" = "Step.Result.Status". You can do this in the Post Expression.
If its after the step has finished ie it the next step, then use "Locals.MyResult" = "PreviousStep.Result.Status".
If it after, but not the previous, then use "RunStatus.Sequence.Main["step name"].Result.Status".
Hope this helps.
Regards
Ray Farmer
Regards
Ray Farmer
(2,913 Views)
It is OK now,thank you.
(2,906 Views)
