NI TestStand
how to solve conflict errors using Test stand 4.1
I am using Test stand 4.1. Previoulsy I was using test stand 4.0. When I am trying to open the sequences saved in 4.0 in 4.1 they are giving some conflict errors. So now my problem is if I have a big main sequence in which I have many more child sequences then I was required to open all the sequences that being called in the main sequence save it and close.
One thing I found is that if once I opened and saved all the child sequences present in the main sequence then it will run fine. i.e. once I clear the conflict error with all sequences, this data is stored in the station globals. If change this again I will be required to do the same job.
This is costing me a lot of time.
Please help me in avoiding this conflict error.
(3,033 Views)
NI Labs has a utility that I have used to check for type confilcts.  Check it out...
NI TestStand Toolkit for Large Application Development
http://www.ni.com/labs/
(3,018 Views)
