NI TestStand
how to pass waveform from a dll to teststand
I have a dll function which outputs a waveform - the dll is compiled in LV 7.1. Can I pass the waveform from the dll to teststand? From Labview it is easy, I choose the LabVIEWAnalogWaveform type for a variable, and I put the waveform in. But if it is possible, how to do it with a dll function? Which caregory schold I use for the waveform by defining the parameter details in teststand?
regards
MB
(3,022 Views)
maybe this helps you:
"Creating a Waveform Custom Step Type and Adding Information to the ASCII Report":
http://zone.ni.com/devzone/cda/tut/p/id/3184
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
(3,000 Views)
