NI TestStand
how to get the "module" in the step settings pane
I´m trying to rebuild an example for "Custom NI VeriStand Steps for NI TestStand". So far es I can see it I did the same things as in the examples. I draged a few stepst from the Insertion palette in the Main Sequence and now I want to specify the module but this button isn´t shown up in the Steps Settings pane.
I´m still a total beginner and have to work with Teststand for my bachelorwork. So please help me 🙂
(3,388 Views)
Which TestStand are you using?
Did you check the examples calling different VI or DLL?
First you select which language your module is built - ex CVI orLV or C++ .....
Then you add an action step type.
In the step settings of action step type you can call a module.
Hope this helps.
(3,381 Views)
