01-21-2011 09:16 PM
Hello All,
I want to execute the some steps synchronously,Such as:one step for setting some input conditions to DUT,and one step for measuring some test points under the conditions.and the measurement is real-time.
So i want to know if have this function can do this.and how to do.
thanks.
BR
Johnny
Solved! Go to Solution.
01-23-2011 12:49 PM
Hey Johnny,
Here is a simple example in TS 4.1.1. I would use a Rondezvous. Basically you create the Rondezvous with 2 threads. Then you spawn a sequence in a new thread (Set DUT). Inside of there you have a Rondezvous step set to Rondezvous. Then another sequence called Acquire Data with a Rondezvous step set to Rondezvous as well.
The way that the Rondezvous works is that you create it first and define the number of threads. Then TestStand waits at each Rondezvous step it encounters until the number you defined has been encountered. Be careful because you could have a condition where you may not encounter enough Rondezvous steps. In this case you can set up the timeout so that it will just continue or terminate if they are never met.
Hope this helps!
01-23-2011 12:54 PM
The other option is to have your code module (LV, C++, CVI or whatever language you are using) have parallel threads that do it synchronously inside of the module itself.
01-23-2011 07:13 PM
Hello Jigg,
Thanks for your reply!
i have tried the example,it is done.But i am not sure i have understood the usage about rendezvous.i want to know what meanning "Get status" in "rendezvous setting" is,and how to use it?
About the second opinion,Since i have used a lot of different conditons and steps,if add the code in the module,it will be mess.So i did not use this.
anyway,Thanks again!
BR
johnny
01-24-2011 09:02 PM
So the "Get Status" option just queries properties of the Rondezvous....such as the 3 options that show up when you select it. You can then store those to variables and use them to determine the next move in your sequence. It's just a way to dynamically make more decisions.
Also, if you look in the TestStand help:
You can use the Get Status operation to get information about the current state of a rendezvous. Select the Get Status radio button on the left of the Rendezvous Settings panel.
The Get Status operation contains the following options:
I'm glad this helped. Good Luck in your application!
