NI TestStand
how to check the show base class members in teststand programatically using c#
I need to check the checkbox indicating show base class members in teststand using .Net adapter programatically through c#.can I get any help.Using CallMethod , I need to call a method "GetItemByName" .It is only possible by enabling the show Base Class Members  checkbox.Any Help?
(4,171 Views)
Using large picture file size attachment isn't very friendly try using a format that generates a small size file such as PNG.
Regards
Ray
Regards
Ray Farmer
(4,167 Views)
bannerghatta -
This is specified by the DotNetModule.MemberFlags property. The DotNetMemberFlags consist of DotNetMemberFlags_Static (0x1) and DotNetMemberFlags_TopLevel (0x2). These can be used individually or you can perform a Bit-Wise OR to use them together.
In your case, the Show Base Class Members check box corresponds to the DotNetMemberFlags_TopLevel (0x2). If this flag is set, the box is not checked. If the flag is not set, the box is checked. Thus, you will either want to set DotNetModule.MemberFlags = 0x0 or 0x1 dependent on whether or not you are using a Static Member.
Since you seem to be doing a lot with the DotNetModule, here is a link to the DotNetModule Help online.
Hope this helps.
Message Edited by Manooch_H on 01-07-2010 09:27 AM
Manooch H.
(4,153 Views)
Hi Mannoch,
If you want to set the check box "Show Base Class Members" you need to pass  DotNetMemberFlags_Static (0x1)
If you set to 0x2 the check box is ! NOT ! enabled.
I am using TS 4.0
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,120 Views)
Juergen -
I agree with you... that's why in my previous post I stated:
I apologize if my statement came off as confusing, but it is otherwise correct.
Manooch H.
(4,117 Views)
