NI TestStand
how to avoid links/paths get converted into tokens in teststand report
 I was trying to get The hyperlink for some of The files in The teststand(4.0) report for a particular custom step made in labview 8.5. I was able to get The link correctly when The path specified does not contain any tokens(\N, \T,\R,\n,\t,\r,etc).
For example if my Folder name is "New" inside which my file is present(C:\NEW\test.txt). The teststand automatically converts "\N" and "\t" in The path to tokens.
I am not able to resolve this.
Can anyone help me in this regard.
Praveen
Message 1 of 9
(4,776 Views)
Accepted by topic author Sury@
You need convert your  \  to  \\.
Regards
Ray Farmer
Regards
Ray Farmer
Message 2 of 9
(4,774 Views)
Praveen,
this is called Escape Characters (search for ecape characters in the link), which is common for (nearly) all programming languages as well. TestStand uses a syntax derived from ANSI C in expressions.....
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 3 of 9
(4,769 Views)
hi Ray,
replacing "\" with "\\" did not solve my problem.
The path which comes from labview VI is :C:\Testing\New Folder\REPORT\test.txt
Message 4 of 9
(4,768 Views)
Ray,
 I was wrong, sorry. Your solution worked good. Need to test more.
Message 5 of 9
(4,764 Views)
Praveen,
you have to exchange every '\' into '\\'. So your path-string has to look like:
"C:\\Testing\\New Folder\\REPORT\\test.txt".
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 6 of 9
(4,762 Views)
replacement of all "\" with "/" will also work.
Message 7 of 9
(4,468 Views)
 I have another query : How to make relative paths working in Teststand report instead of giving absolute path?
                                    This query is because if I want to open the report in another PC, it opens good, but when I try to double click to open the link in report it does not, even if the file is placed in the same place where it was to be. So I wanted the link given to the relative instead of absolute.
Surya.
Message 8 of 9
(4,460 Views)
I got the soultion for my query, working on it for an hour.
Solution:
If the path for the text file which was linked in report was :C:\Testing\New Folder\REPORT\test.txt
and if the report file is parallel to the test.txt file: C:\Testing\New Folder\REPORT\test.xml.
then for the link for absolute path in report :  C:/Testing/New Folder/REPORT/test.txt
               link for the relative path in report : "test.txt"
If the path for the text file which was linked in report was :C:\Testing\New Folder\REPORT\files\test.txt
then for the link for absolute path in report :  C:/Testing/New Folder/REPORT/files/test.txt
               link for the relative path in report : "../test.txt"
This is working for me, hope this works in every case.
Praveen.
Message 9 of 9
(4,420 Views)
