NI TestStand
how create a DLL with module python?
I am a beginner in TestStand,
I would like to know, how create a DLL with module Python? because for create a sequence, we must own a DLL.
Thank you for your answer
Vincent
(5,355 Views)
Can you describe more precisely what you want to do ?
You can call a dll made in C/C++ using the code module C/C++ DLL. You can build that kind of dll with LabWindows CVI for example.
Regards
(5,342 Views)
I would like use TestStand with Python module. So I believe, we must use a DLL for execute a test, I'm wrong because I can use .exe for realize a test.
Now I know how use TestStand with Python module but I have a mistake. I wonder which is error 255?
Whereas I use .exe in Language C, I have no error.
Thank you for your anwser.
Vincent
(5,338 Views)
Accepted by topic author vince11
I found my answer.
Error caused by the user exit program not being able to load the library file for the executable
I resolved my problem.
Vincent
(5,223 Views)
