NI TestStand
flextronics test stand
I am new to labview, and just wanted to run a costum made test stand made by flextronics for our company which uses labview. I installed everything and copied all the file following the installation guide but I keep seeing errors when I open the test stand. the errors are:
first error is when I open the program(FTS):
Error 5003 occured at FTX_UI-start execution-V007.vi
**test stand error**
possible reasons: Error starting PM entrypoint This migth happen when some test modules cant be loaded
the second arror is when I try to load a test withing this program:
"Error 1000 occured at Invoke Node in FTX_UI_create async socket handlers-v005.vi>FTS_UI_main-v200.vi
**Internal GUI error.The program will be closed**
Possible reasons: The VI is not in a state compatible with this operation"
It might seem so stupid I copied senrence by sentence the error I get because I don't have any idea about labview. I guess some config files or mdb files are missing but not really sure.
I would appreciate if someone familiar with labview or flextronic could help me in this.
(3,052 Views)
You should probably contact Flextronics about this.
CTA, CLA, MTFBWY
(3,018 Views)
