NI TestStand
error -2146959355 server execution failed on ActiveX Invoke Node?
I wrote a VI to reload all the module prototypes of the steps in a TestStand sequence (note: all code modules are LabView VI's).  Whenever it gets to the LabViewModule.LoadPrototype call, I get a "server execution failed" error (error code -2146959355).
I've tried solutions 1-3 in the following document to no avail:
Why Do I Get Error -2146959355 When Using ActiveX or the Report Generation Toolkit?
http://digital.ni.com/public.nsf/allkb/1c025f018cb5761686256c56007dd258
Any ideas as to what else I can do?
(Incidentally, if anyone has a clue as to what reference is causing a "References to PropertyObjects were not released properly" warning dialog... please do say).
Melissa
(4,408 Views)
Hi Melissa,
I think it would be a better option for you to perform this task in TestStand. See the attached example that is tested and works on reloading LabVIEW module prototypes.
Hope this helps!
Best Regards
Jonathan N.
(4,391 Views)
Can you tell me what version of Teststand and Labview this solution is written for?
Vickie
(4,123 Views)
Vickie,
An updated version of this sequence can be found at the Developer Zone at:
Reload LabView Prototypes Programatically
and is written in TS 3.1.
NickB
Applications Engineering
(4,105 Views)
