02-08-2006 02:10 PM
02-09-2006 12:34 PM - edited 02-09-2006 12:34 PM
Hey plf,
Have you seen this Discussion Forum. I think it is very similar to the error you are seeing. Try the steps in there and if that fails then let me know and we'll see what else we can figure out.
You need to open the Database.seq file inside of this directory: C:\Program Files\National Instruments\TestStand 3.1\Components\NI\Models\TestStandModels\Database and go to the Edit Database Options from the View drop down. Then you can right click on Create UUTResult and click on Specify Module. Yours should be similar to the one I'm attaching. Check and make sure it is.
Message Edited by Sam R on 02-09-2006 12:47 PM
Message Edited by Sam R on 02-09-2006 12:48 PM
02-10-2006 06:11 AM
Sam...
Thanks for the reply.
1. I have tried the version selector several times with no luck. FYI: I have version 3.0 and 3.1 listed in the drop down menu.
2. I went through and selected the dll in the specify module popup but I don't get the correct Automation Server nor can I find the one that you have. See attached image of the window.
Also I have uninstalled and re-installed TestStand prior to this.
Peter
