NI TestStand
editing posts
How does one edit a previous post?  Is it possible to remove/replace an attachment?
(3,203 Views)
Hi, mrbean,
Typically it is not possible to modify previous post, unless it's only a few minutes since the message has been posted. You may post a new message for the attachment.
Song D
Song Du
Systems Software
National Instruments R&D
(3,171 Views)
mrbean,
If you absolutely need something removed from a previous post then you can possibly get the Moderator to edit it.  Go to the thread and click on Options>>Report to a Moderator.  I am attaching a jpg on how to do this.  I'm not promising they will remove it or edit it but they do have the power and if your case is strong enough they just might listen.
As Song said in his post- 30 minutes after you post you can edit your own message by going to Options>>Edit Message.  It will only show up if you are allowed to edit the message.
Message Edited by Sam R on 09-17-2007 10:39 AM
Message Edited by Sam R on 09-17-2007 10:40 AM
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,153 Views)
