NI TestStand
dynamically creating an array of containers
   I am am using Test Stand 4.2 and want to create an array of containers dynamically.  The number of containers comes from the device that I am testing.  What are the steps necessary to do this, The array element container will contain 3 numbers and an ascii string.
(4,309 Views)
Accepted by topic author wrroberts
I do this using the SetNumElements method.
1) Create a custom data type for a container that has your number and string elements
2) Add a local variable in your sequence that is an array of this new type (and check empty box)
3) Add a function call in your sequence similar to:
SetNumElements(Locals.LocalContainerArray, Locals.NumElements)
Locals.NumElements is a variable for the size of the array.
Hope this helps.
(4,301 Views)
