NI TestStand
deploy run time engine
Hello everybody,
I am trying to deploy my teststand application to a target computer. My teststand application uses: TestStand 2014 (32 bits), LV 2014 SP1 (32 bits).
Following is the problem I encouter while using the deployment tool.
1. While trying to include the LV RTE into my installer, the deployment utility is requesting that I provide LV 2015 installer. See the attached picture.
I wonder why it is asking for LV 2015-64bit installer median. If I ignore the request, the build process failed.
2. I am using shared variable to communicate with the compactRIO controller. The compactRIO controller is the SVE host. My question are,
       a. Do I need to 'deploy' my shared variable library, eventhough my system is not a SVE?
       b. I read in manual that I can deploy the shared variable libry through the LV utility deploy lilbrary step. So I added this step into the test sequence. Everytime I run the sequence, that step deploys the shared variables. On the target, I wonder if it is necessary to deploy the shared variable on every execution of the test sequence. I think it should only be deployed only once on the target system. Am I right? If so, how do I remove that LV utility deploy library step from the test sequence on the target, since there is no test stand development system on the target.
3. I am using a database to save the test results after each test sequence execution. I can export the database table schema and copy over to the target computer. My question is, how do I import the database table schema into the target, since there is no teststand development system on it (no way to call up the Configure->Result Processing->Database to import the table schema)?
I hope the teststand experts out there can provide me some helping hints to help me understand the whole deployment process. Thank you.
Yours,
lhuckj
(4,616 Views)
Accepted by topic author hlim
1) Make sure LabVIEW 2015 Run time is NOT slected from Installer options -> Drivers and Components
2) I don't know
3.
I generally set my data link to a  UDL file and include that in my distribution .  I set the  coonection string to use a relative path to this udl and make sure the UDL is copied to the same location on the targer
I also include in my CFg TestStand Application Directory:
TestStandDatabaseSchemas.ini
TestExec.ini
Users.ini
StationGlobals.ini  (careful if you don't want to overwrite the existing one; i use it to store instrument addresses)
(4,602 Views)
Hello NIExpert, thanks for the hints.
I have not included the LV 2015 Run Time. But I noticed that as soon as I included the 2015 Test Stand run time, it immediately requested LV 2015 Run Time Installer.
Thanks for the tips on the .ini files you included in your deployment.
Yours,
hlim
(4,584 Views)
