NI TestStand
change teststand post actions from labview
Is there a way to change the post action of a test in teststand from Labview.
At the moment, if one of the tests fail out of limits then the post action is set to 'ON FAIL - GO TO NEXT STEP' but if the unit does not run then a diagnostics labview routine runs and at the end of that I would like to change the teststand post actions to 'ON FAIL - GO TO CLEANUP'
Can you tell me if this is possible
Chris
(3,348 Views)
Rather than have this in your code module you should look to use the SequenceFilePostFailure to alter the direction your sequence takes.
You can find an example of using this callback in the TestStand Examples.
Regards
Ray Farmer
Regards
Ray Farmer
(3,342 Views)
Hi
Yes it should possible.
Step step = m_SequenceContext.Step; if(nValue == 0)
step.FailAction = "Next";step.FailActionTarget =
else
step.FailAction =
"Goto";
step.FailActionTarget = "<End>";
Regards
Juergen
EDIT: This example Goto Endgroup --Sorry!
Message Edited by j_dodek on 04-21-2010 01:51 PM
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,333 Views)
