NI TestStand
change step status from "error" to "failed"
I'm using TestStand 2012   and I want to do the following:
1. Ignore a Runtime Error from a  particular step.
2. If receiving an error from that step, jump to 'Cleanup'.
3. Change the status of that step to 'Failed' instead of 'Error'.
I was able to satisfy issue 1 above by selecting 'Ignore Run-Time Errors' from 'Run Options'.
I was able to satisfy issue 2 above by creating a 'Custom Condition' of Step.Result.Status=="Error" from 'Post Actions'.
I have not been able to satisfy issue 3 above.  I tried 'Step.Result.PassFail=False' as a 'Post-Expression' from 'Expressions' but that didn't work.  The step I'm working with started out as an Action step.  Then I changed it to a Pass/Fail step in hopes that I could change 'Status Expression' from 'Expressions' but I couldn't.  I would rather leave the step as an Action step if I could.
(5,768 Views)
There is an another forum post regarding changing status of the step. Solution provided in the other post might help in solving your issue.
- Shashidhar
(5,716 Views)
Accepted by topic author VI_Joe
Thanks!  This did help.  I used Option 1.
(5,704 Views)
