NI TestStand
change step parameters order
Is it possible to change the parameters order?
Or are they locked and only defined by the connector pane?
(4,850 Views)
As stated in the TestStand Help for the LabVIEW Module Tab:
"The VI Parameter Table displays parameters according to the order in the VI context help image"
However, you could cluster the controls within the VI and then re-order the controls in the cluster so they appear in the order you want.
Charlie
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(3,230 Views)
Better late then never. 🙂
I now used subsequences, there I can set the parameter  and order, and only the needed parameters are present.
gr,
Bart
(3,219 Views)
