NI TestStand
c++ parameter discription changes!
Hey everybody,
i've got a problem with the parameter discription!
Normally it works fine and every Parameter has its assigned Description!
My functions always have an Parameter called 'aubyTelegram', an unsigned char array with different Length for each function!
If I create an Local Variable in TestStand and select it in the Value Expression for Function1, everything is fine!
If i change the function to Function2 with the same Parameter 'aubyTelegram', the Value Expression automatically adopts the Local Variable in the Value Expression, what isn't a big Problem...
But it also adopts the Description of Function1, so the array Length has always to be aligned to its assigned Function!
Is there any Option to disable the adoption of variables for Value Expression and the Description?!
Kind regards,
Dag Ennenga
(3,354 Views)
Hi Dagger1987,
can you send us an example or a sequence with your C++ Expression or DLL?
Can you explain the Issue with more details?
Kais Mekacher
Germany - Munich
(3,332 Views)
