NI TestStand
are locks necessary around a single file write instruction?
I am running 14 processes in parallel in TestStand, and each process will call a the "Write Text File" function occasionally.
Can one process's file write interrupt another one during mid-write, or do I need to put locks around each write?
(3,105 Views)
Accepted by topic author bmihura
If you are accessing the same file then lock is required.And that too when you are writing to it.
(3,087 Views)
OK, thanks. I'll arrange it so that different files are accessed per thread.
(3,082 Views)
