NI TestStand
Why is there a connection to akamaitechnologies.com when starting TestStand?
Isnt it better to put the config-file next to my custom C#-GUI.exe that is calling the Teststand-API?
I am not calling seqedit.exe anywhere direct.
Message 11 of 15
(1,504 Views)
Sorry, I had not reread that you are using a C# app. If you are compiling the C# application, you can add the setting to the app.config file in your Visual Studio project. Otherwise, you can add an appropriately named <exename>.exe.config file with the setting next to your application EXE.
Scott Richardson
https://testeract.com
Message 12 of 15
(1,498 Views)
Ok.
I also tried to put the file to seqedit.exe but i dont have access in this folder in my Widows 10.
Explorer is started in Administaror-mode but it says "access denied" in folder C:\Program Files (x86)\National Instruments\TestStand 2017\Bin.
What can i do to create this file?
Message 13 of 15
(1,492 Views)
You must have administrative authority to place the config file next to SeqEdit.exe under the program files directory.
Scott Richardson
Message 14 of 15
(1,484 Views)
Since we have not diagnosed the issue you are hitting, I would suggest also updating to NILM 4.2 or later.
Scott Richardson
Message 15 of 15
(1,480 Views)
