NI TestStand
Why a value of Sequence File Global didn't change ?
I change the Sequence File Global into ModelOptions subsequence, but after that in MainSequence I see that the value isn't changed. Why do I have the problem?
(3,503 Views)
Have you set the Sequence File Globals to "All Executions Share the Same File Globals" in the SequenceFile Properties?
Regards
Ray Farmer
Regards
Ray Farmer
(3,501 Views)
No, it was "separate...." 🙂 I didn't know, thank you!!!
(3,499 Views)
But it didn't help :-(.
I set to "Share...", I have the same problem. Why?
(3,497 Views)
Sorry, it works.
Thank you !
(3,496 Views)
Thats okSmiley Happy
Regards
Ray Farmer
Regards
Ray Farmer
(3,492 Views)
