NI TestStand
Version Control in TestStand
Hello All,
I would like to create a version controlled project structure in TestStand 2017.
I searched NI forums and other sites, but the information is not so detailed regarding this topic.
I tried with TamTam SVN SCC plugin, which was reaaaally slow, and PushOK SVN SCC plugin, this is providing some errors. (unsing TortoiseSVN)
I would prefer built in solutions with Teststand first.
Do you use version control?
If so which one do you use and why?
Do you know any tips how I can setup my environment?
Thank you in advance.
CsBihacker
(4,748 Views)
Hi Bigyo,
At some point I was using Perforce and it worked pretty well. It is also mentioned as actively tested by NI with TestStand. I see there also SVN (PushOK plugins).
http://zone.ni.com/reference/en-XX/help/370052N-01/tsfundamentals/infotopics/scc_selecting/
Did you see this doc?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Kh2SAE
Best Regards,
TK
Certified LabVIEW Architect (CLA)
(4,680 Views)
Hi TK,
Thanks for the reply.
I read all what is available in NI forums, googled the hell out of it already 🙂
I'm interested in pros and cons about SCC solutions.
CsBihacker
(4,678 Views)
Does anyone has experience to use Git or Bitbucket with TestStand code management?
CsBihacker
(4,313 Views)
