NI TestStand
Using property loader with Excel
I am trying to load properties from and excel spread sheet into multiple 1D local arrays. The names of the arrays will be same as the values in the cells of the first row. The step names are same as those in the first column or any other column. My test file varies, so I cannot specify the sizes of the arrays. Can some one pleae help me get started with this ? maybe with a small example. I attached the excel file with some sample data
Sam
(3,555 Views)
Check this link out (TestStand Property Loader doesn't load all properties).
This one got me going. You may need to create your own Sequence File Type under Custom Data Types to acheive this though.
-Chroma
(3,544 Views)
The problem is going to be that your file is not in the format the PropertyLoader expects which is
START
<Step Name>
<Locals> Variable Value
CFG_FEATURE[0] 0
CFG_FEATURE[1] 0
<FileGlobals> Variable Value
<StationGlobals> Variable Value
END
Therefore if its has to be that format then you will have to create your own PropertyLoader step
Regards
Ray Farmer
Regards
Ray Farmer
(3,543 Views)
