NI TestStand
Using Parameters.UUT.AdditionalData
In addition to a UUT.SerialNumber and a UUT.PartNumber, I have a MSN number that needs to be logged. I added the string Parameters.UUT.AdditionalData.MSN and checked Advanced->Edit Flags->Include in Report.
I overrode PreUUT in this simple example, but when I test UUTs the sequence terminates after running PreUUT. It's probably something simple. Can someone please take a look?
StephenB
(5,764 Views)
It seems that making this direct assignment in a statement step is causing the PreUUT sequence to stop running:
    Parameters.UUT.AdditionalData.MSN = "MSN123"
Why is that I wonder?
(5,758 Views)
Hi Stephenb2,
That's very interesting.  I couldn't say why you'd be seeing that, but I'd suggest experimenting with different options of the UUT variable.  Perhaps you could try without including it in the report, and defined as a local rather than a parameter initially. We could also verify that no necessary functionality was overwritten in the PreUUT callback to ensure proper execution.
Andy G
Applications Engineering
(5,674 Views)
