NI TestStand
Using Labview Data type with TestStand
Hi ,
i need some help in the configuration of the parameters in the ring control in step settings
i'm calling a VI in TestStand to control a power supply so when i run the VI i need to enter this command string : "TRIG : SOUR IMM
                                 VOLT:TRIG 5.0
                                 CURR:TRIG 3.0
                                  INIT"
thank you
Ahmed Kochbati
Electronic Engineer
(2,781 Views)
For accessing Ring control in TestStand, Use a VI with Ring Control as a input node which will automatically gets detected in TestStand Parameter Values.
(2,749 Views)
