NI TestStand
Using LabVIEW RTE vs. LabVIEW ActiveX Automation Server (TestStand LVRTS) for a TestStand Deployment and experienceing Unabel to Launch LabVIEW.Application ActiveX Automation Server Error 18001
I am developing in TestStand 4.2.1 and LabVIEW 2009, I have accomplished the following:
1. Deployment package is built and deployed on PC
2. PC has activated TestStand Deployment License
3. LabVIEW 2009 RTE was selected as the adapter for the sequence and thus I believe the deployed testexec.ini contains this.
I  am experiencing the following error: "see attachment".
Is the LabVIEW RTE the right selection?
Is there something I may have missed in building the deployment?
Do I need to register the ActiveX server.
THere seems to be conflicing solutions based on Version of TestStand and LabVIEW!!
Thanks!!
(5,292 Views)
Is LabVIEW 2009 RTE actually on the target system?
Regards
Ray Farmer
Regards
Ray Farmer
(5,282 Views)
Howdy mobiux,
Please consider KnowledgeBase 4V58058Z: -18001 Errors in TestStand. You might also consider ensuring you have the proper LV version active in the TS Adapter Options.
Warm regards,
pBerg
(5,270 Views)
"Is LabVIEW 2009 RTE actually on the target system?"
Yes, see attached!
(5,256 Views)
Thanks for all your suggestions. In the end it seems to have been the testexec.ini file; when I changed to the run time engine adapter setting, and copied the testexec.ini to the deployment machine, it solved the problem.
(5,212 Views)
