NI TestStand
User Manager
I am facing a problem with the TestStand User Manager. I logged in as an Administrator. In the User Manager, I created a new user, configuring him as a Developer . I saved the changes and logged out. I again logged in the Developer account. Now, in the User Manager, TestStand allows me to configure only my account's(the developer account) password. This is because of the Privilege "Configure.Edit Users" set to False for a developer. But when I logout and login again in the Developer account, TS allows me to change even the Administrator's account and the Developer's Group Privileges or any other account's password and privileges. Why is this happening???
During the second time login, if I change the Developer's Group Privileges to only Developer, then for the next login it works properly. Again for the next login, TS allows to change any property.... Why is this happening?
I am using TS3.5
Message 1 of 11
(5,487 Views)
That does sound strange.
Just to clarify what you are doing.
a) Created new user (as a developer)
b) logged in as new user, only allowed to changed passwords of new user.
c) logged out / logged in as new user. Now able to change any account, even the administrator.
d) change new user as developer, save and logged out
e) repeat as for b) etc.
When you log out do you close TestStand or do you just use the menu item File | Logout... .
regards
Ray Farmer
Regards
Ray Farmer
Message 2 of 11
(5,480 Views)
That's right... Did u check that with your system?
This happens even if I logout by File | Logout or quit TS completely and start it again.
Message 3 of 11
(5,478 Views)
I tried that using TS 3.5 and I am not seeing the same as you.
The only propery I can change is the password when logged in as a developer user and I can not cahnge any properties of the admininstrator, as expected.
Regards
Ray Farmer
Regards
Ray Farmer
Message 4 of 11
(5,462 Views)
Hi
The first time I login as a developer, everything will work fine. But from the next time onwards, it doesn't work as intended....
Regards
Sahana
Message 5 of 11
(5,456 Views)
Yeah, I tried that.
I'll repeat the exercise later.
Regards
Ray Farmer
Regards
Ray Farmer
Message 6 of 11
(5,454 Views)
Hi Sahana,
We have duplicated this behavior and discovered it to be a bug within TestStand 3.5.  This has been reported to R&D for further investigation.  For now, the best workaround is to not include the functionality to add/change user privileges within the OI.  Sorry for the inconvenience.
Message Edited by Support on 08-10-2006 02:29 PM
Message 7 of 11
(5,442 Views)
Terry,
Was that in an OI or the SeqEditor or both?
Regards
Ray Farmer
Regards
Ray Farmer
Message 8 of 11
(5,436 Views)
Hi Ray,
Sorry, I forgot to specify this.  This bug is only in the sequence editor.
Message 9 of 11
(5,425 Views)
Hi Ray and Terry,
Thanks for your information.
Sahana
Message 10 of 11
(5,386 Views)
