NI TestStand
User Expression To Specify File
When editing the Source tab of the Property Loader there is an option to "User Expression To Specify File". This is what I want to build:
"C:\_views\AutomatedTests\" + FileGlobals.BoardType + ".txt".
How would one compose this into a usable expression?
thanx,
jvh
(3,528 Views)
Accepted by topic author jvh75021
"C:\\_views\\AutomatedTests\\" + FileGlobals.BoardType + ".txt"
This should work...
Sathish
(3,513 Views)
Thanks.
Interesting that with the top radio button where you specify an absolute path single backslashes are OK but with the lower button where the adress is calculated doubles are required.
(3,501 Views)
