NI TestStand
UseCompExpr Error while saving file in older format
All,
I have a sequence that:
1. Was Developed in TestStand 2.0.1
2. I am opened in TestStand 4.0.1
3. I want to save it back in version 2.0.1
WHY: Ease of use in newer TestStand GUI.
But I get a UseCompExpr error >>> unknown variable
Any ideas would be appreciated.
thanks
Message 1 of 11
(4,839 Views)
The only place I know that UseCompExpr is used is in the test step properties.  It looks like the step types have changed since versions.  When you tried to back save it doesn't know what to do with that property or how to use it.
It's used in the String Value Test, Multiple Numeric Limit Test and the Numeric Limit Test.
Hope this points you in the right direction.
Honestly though I'm not sure what you are doing is supported or recommended by NI.  I can't speak for them though.  TS 3.0 was a major overhaul to TestStand and any version previous I consider ancient and wouldn't personally consider crossing that line.  My 2 cents.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 2 of 11
(4,824 Views)
Thanks for the information, it helps a lot.
Everything you say is correct about the version etc.. but this environment is the working one.
Thanks again.
If anyone else out there has a different incite I will always listen.
Message 3 of 11
(4,818 Views)
What do you mean by "but this environment is the working one"?  Are you saying that the deployment machine only has the 2.0.1 engine on it?  Therefore you have to deploy to that engine?
jigg
CTA, CLA
testeract.com
Message 4 of 11
(4,812 Views)
That is correct
Message 5 of 11
(4,810 Views)
Is it an option to upgrade the deployment bench with a newer engine?
Do you see the error when you load the sequence file or when you try to run the sequence file?  Is the error only in the 2.0.1 UI?  Or do you see it when loading the file back into the sequence editor?
jigg
CTA, CLA
testeract.com
Message 6 of 11
(4,808 Views)
Upgrading is not an option.
The software works fine in 2.0.1
The problem is if I try to save it as a 2.0.1 file FROM the 4.1 version of TestStand environment.
Message 7 of 11
(4,806 Views)
I understand that upgrading is not an option.  I have seen similar situations.
So basically in the 4.1 sequence editor when you try to save it you get the error?
What happens when you save to an older version?  Or even save it to 3.0 and then try and save it again to 2.0.1?
I just tried a sequence with all the test types in them and didn't see any issues.  However, I am using TS 2010.
jigg
CTA, CLA
testeract.com
Message 8 of 11
(4,800 Views)
No upgrade possible
Tried to go back to 3.0 from 4.1: no go on that
Message 9 of 11
(4,795 Views)
Not sure if it's possible to post your file or narrow the issue down to a couple of steps and post that file but I could try it out and see if I can reproduce your issue on 2010.
Long term this doesn't seem like a viable option but at least we could see if the bug was in the 4.1 editor.
jigg
CTA, CLA
testeract.com
Message 10 of 11
(4,789 Views)
