11-19-2010 03:30 PM
02-04-2011 07:58 PM
The CVI User Interface that ships with Teststand can be found in the directory ...\Program FIles\National Instruments\TestStand 4.1.1\UserInterfaces\FullFeature\CVI. Mods will be needed to send the value to TS which can then change the station global file or write to the global file from CVI UI.
02-09-2011 02:14 AM
Are you sure you want to change the StationGlobal file or just change an actual StationGlobal variable. When the UI closes and shuts down the TestStand engine the StationGlobal file is updated automatically.
