NI TestStand
Unable to load sequence!!
I have a sequence which was previously loading properly but now it refuses to load due to an apparant "Incorrect File Format" error (see attached image). It's very important I get this sequence to load other I will have lost a lot of work. Does anyone have any suggestion? TIA.
(4,031 Views)
What version of TestStand are you using?
regards
ray farmer
Regards
Ray Farmer
(4,019 Views)
I am using TS 4.2.
(4,017 Views)
So the seq file was probably saved in the binary format. Is that a network location, and if so do your IT people do backups in the evening?
Otherwise, I dont think there is much you can do.
regards
ray farmer
Regards
Ray Farmer
(4,014 Views)
Thanks, that's what I'm looking into right now. Is it advisable to save my sequences in non-binary format?
(4,011 Views)
You might have been able to recover something, but more importantly would be to make regular backups using some tool such as SourceSafe or something similar.
Regards
Ray Farmer
Regards
Ray Farmer
(4,002 Views)
