NI TestStand
Unable to load VIs in Run time engine
Hi All,
We are using 32 bit LabVIEW in 64 bit TestStand in our application.
32 bit LabVIEW is require because we have 32 Bit DLL that cannot be used in 64 bit LabVIEW and we are using Digital pattern instrument that require 64bit TestStand and TSM. So we cannot change the configuration.
Problem statement:
In run time engine we cannot able to load the VIs. please find the below error:
I'd Appreciate any help on this issue.
Best Regards
Manasa M
(2,787 Views)
64-bit TestStand can only use 64-bit LabVIEW Run Time Engines.  Maybe you can find a 64-bit version of your DLL?  Or recompile it in a 64-bit configuration?
(2,783 Views)
Thanks for the reply.
But unfortunately we don't have a  32 bit DLL and it is not possible to get it re-compiled also.
Best Regards
Manasa
(2,779 Views)
