NI TestStand
Types resource file is binary
I started using TestStand in 4.0, I know earlier version saved in ascii, is there a setting to change how ini files are saved?
(3,400 Views)
Configure>>Station Options>>File Format Options and Edit>>Sequence File Properties>>File Format.
(3,396 Views)
If you want a text-based, human readable format you might want to try xml. If you have a large number of types, binary will be faster to read (for type palettes that means faster startup of the application).
-Doug
(3,370 Views)
