NI TestStand
Two reports with different steps recorded
In TestStand, I have two reports enabled in Result Processing.  I'd like one report to have all of the step results and the second report has "Result Recording Option" disabled for a number of the steps.  Essentially, one report has more detail and the other is more of a summary.  Is there a way to programmatically disable result recording for a specific report in Result Processing while enabling it for the other?
(2,261 Views)
Yes, you can do this!
You can decide to not record data from a sequence file, but then choose to record it for one step of the sequence file.
The Report Generation and Customization goes over the different options.
Thanks!
(2,181 Views)
