NI TestStand
Traversing through Array
I am trying to have an array of say size 30 and I want to traverse through it one by one and display the results digitally.
I tried using INDEX ARRAY function but keeps on giving me a constant value and does not traverse through to the next element after displaying first one.
Any advice please.
(3,358 Views)
I'm not sure I understand what function you tried to use. If it's the PropertyObject.GetArrayIndex, then the function will always return the array index string at a given offset in the array.
The clasic way of traversing an array is to define an index for iterating, for example: Locals.index.
Next insert a Label and a GoTo step.
The GoTo step has to be configured as follows:
1. Destination - 'Label'
2. Precondition = Locals.index < GetNumElements(Locals.Array)
3. PostExpression = Locals.index++
In between the Label and GoTo step place your steps for accessing the array elements, based on the Locals.index.
Hope this helps,
Silvius
Silvius Iancu
(3,348 Views)
What Silvus said is correct, but there are a couple things that you may want to keep in mind.
1. If you have TestStand 3.1, there is a "For Each" function that will loop through the arry for you.
2. If using TestStand 3.0 or earlier use something like this (don't forget to initialize the Index:
Assume array size of 30, from 0 to 29,
Statement Step: Initialize the Locals.nIndex=1
Label Step: Top Of For Loop
Steps for Array: Calulate Array Value...
Expression: Locals.nMyArray[Locals.nIndex]= ...
Goto Step: Goto Top Of For Loop,
Precondition: Locals.nIndex<29
Post Expression: Locals.nIndex++ 'Increment the Index
Mike
(3,338 Views)
