NI TestStand
Transmit Receive same port.vi
I'm trying to send CAN messages via TestStand. The equipment i'm using is the NI USB-8473, and from the provided examples - 'Frame - Basic.llb', i am successfully sending the mesages using the 'Transmit Receive same Port.vi'.
However trying to call this vi from TestStand is proving difficult.
I suspect the Arbitration Id is incorrect. In the 'Transmit Receive same Port.vi' front panel i am entering "8FF0201", and in TestStand - Parameter Type = Numebr (U32) i use "419365377" but the expected result in UUT doesn't occur.
I don't know how to debug this?
The Highlight-Function is LabVIEW although active seems to be bypassed.
can anyone help.
regards
Kech
(4,044 Views)
419365377 == 0x18FF0201 ( in your posting the initial 1 is missing).
Assuming its a typo mistake what error/failure message are you getting?
(4,040 Views)
the postin was an typo. I do use 0x18FF0201 on Front Panel.
I now think the 419365377 from TestStand is ok. But am wondering how the Buttons for Write & Stop are to be controlled from TestStand.
I call the vi - with Stop= False and Write = True - but then the vi should continue running until i change Stop to state True.
I suspect i have to redesign the vi. Any ideas how?
regards
Kech
(4,031 Views)
I got it - simply changed while to for...
(4,017 Views)
