NI TestStand
Tools >> Update Sequence Files does not update Types
This post implies that Tools >> Update Sequence Files will update the Types
https://forums.ni.com/t5/NI-TestStand/Update-All-Sequence-files-automatically-Types/td-p/2319322
But yet another post claims it does not.
https://forums.ni.com/t5/NI-TestStand/How-to-mass-compile-types-after-Labview-update/td-p/3822095
I have tried the Update Sequence Files tool for the explicit purpose of updating my sequence files to the latest process model / engine type definitions and have found that the types remain unchanged.  In particular the Type that needed updating was NI_ModelPlugin (Update needed because changing from TS 2016 SP1 to TS 2017)
Can anyone confirm if the Update Sequence Files tool is supposed to update Types?
(2,838 Views)
Accepted by topic author ee-jallen
I do not see anything that specifies that tool for updating types. The help menu states that the "Sequence File Converter", which opens when you go to Tools >> Update Sequence Files is used to resave sequence files and it can be used to ensure that a group of files are updated so they load as quickly as possible.
Here is some information about the tool:
https://www.ni.com/docs/en-US/bundle/teststand/page/sequence-file-converter.html
(2,802 Views)
Thanks for your input.  I found that the Diff and Merge Utility will update Type definitions if option "Automatically Merge Types" is enabled.  I have experimented and this appears to upgrade the sequence files as desired.
(2,800 Views)
