NI TestStand
Teststand property loader for multiple sequences
Hi, I am using Teststand 3, and would like to be able to Export all sequences into one Excel spreadsheet, so that each tab references a single sequence. If anybody has already done this, or has a suggestion as to how to do it, I would be grateful. The end goal is to create a single excel file, that can be emailed around, without people losing track of all the different excel sequence files.
(3,090 Views)
ADL,
Unfortunately, there is no way to do this with the property loader features of TestStand. The Import/Export Property tool does not distinguish between worksheets in a workbook and the Property Loader step type can only import properties. If you really need this functionality, one possibility is to use the ActiveX methods exposed by Excel to populate an Excel workbook.
Matt P.
(3,090 Views)
